Briefly describe your issue:
Answer: I am using Anroid 12
Is your Brave Rewards Profile currently verified? (yes/no)
Answer : No
What date did you connect a your Brave Rewards Profile?
Dot not Remember also one years
Yes
Are you using a VPN? (yes/no)
No
Yes . I am live in turkey
No.
Have you manually turned off Auto-contribute on all of your devices?
yes
Hello, I haven’t been able to receive Brave Rewards for about 3 months. I click on the “Request” button, but I get the message “Oh, something went wrong”. and the “request” button comes into the mix again, I click the “request” button again. And I’m getting the “Oops, something went wrong” warning again and this process continues again. Can you help me?
