I recently got a problem with displaying web pages. Here’s the result in brave browser and edge browser of facebook page. This is not the only webpage that displays incorrectly. I disable every extension in the browser and still same issue appears.
what your shield setting set them to standard for tracker and fingerprint
change the cookies to only cross site
also check the shield setting for the site you acceess click on the lion icon while you browse the website to make sure it has the same settings
look at brave://adblock/
maybe to many boxes are checked.
it should look like this (depending on your county, sure)
what about turn off shield completely ?
I turned off the shield, still nothing. “Oficjalne Polskie Filtry do AdBlocka, uBlocka Origin i AdGuarda” was the only box that has been checked, Rotblut I tried your configuration and still some elements were falling apart on the web page.
I tried all settings back to default and not worked for me, then I tried to install again Brave browser and the Facebook page still appears incorrectly.
This issue appears rarely on webpages. At the moment I test only the Facebook page. If I find another page that appears incorrectly I’ll post here
could you disable all extension and use private mode
Nothing happened, I also cleared browsing data- cookies and cache of all time
what about create new profile to test
I suggest to turn this off.
And check the others two below, as your standart on:
Oficjalne Polskie Filtry Przeciwko Alertom o Adblocku
Oficjalne Polskie Filtry Przeciwko Alertom o Adblocku - Uzupełnienie
Problem solved. I changed the minimum font size from 17 to 13 in the brave://settings/fonts
Thank you to everyone involved in this post
