Popup/menu not showing on multi-monitor setup
Popup windows and menu not showing on multi-monitor setup.
I have 3 monitors:
  • 1920x1080 (set as primary) laptop screen
  • 2x 2560x1440 connected via displaylink
Page popup info (“Do you want to close?” etc…) and browser menu are not showing on primary display. Popups make it look like browser have hanged.
Menu:
  1. Move Brave window to smaller screen (primary display)
  2. Open brave menu
Popup (i tested it with jira):
  2. Open issue and start editing comment
  3. Try to close tab
  4. Jira shows popup warning about losing data (not visible on screen)
Popup/menu showing on current screen
Wersja 0.69.135 Chromium: 77.0.3865.120 (Oficjalna wersja) (64-bitowa)
You can get around the issue by moving Brave to another monitor.
