Briefly describe your issue:
I verified my Gemini wallet and then the funds disappeared and were never transferred. I had over 0.250 bat in here.
windows 10 Pro 64Bit - [
Version 1.37.111 Chromium: 100.0.4896.79 (Official Build) (64-bit)
yes
5 Hour
no, first time
Are you using a VPN? (yes/no)
no
yes
not an android
Have you manually turned off Auto-contribute on all of your devices linked to Gemini??
Yes
