Running the latest public build on Windows 11 (This issue happens on any machine I have it installed on)
Many popup browser options like saving a password or similar do not respond to the first click of clicking ok, or save or just hitting the X to close a popup… They always work on the second click, but clearly this isn’t supposed to be a double click thing. This started happening about 6 months or so ago, and it happens on a brand new computer build with a fresh download of brave, so it’s not machine specific.
What’s going on here?
This is a known issue we have open here:
opened 10:51PM - 03 Mar 25 UTC
bug
feature/settings
OS/Desktop
### Description
Often times when the browser prompts you with a modal to perfor… m an action, you have to click the button twice in order of the action to go through.
For example, the `Save password`/ `Update password` prompt that appears often requires you to click `Save` or `Update` twice in order to dismiss the prompt.
Prompts like this should should require only one click of the button to dismiss.
### Steps to reproduce
1. Login to a website in Brave
2. When prompted, elect to save the password in Brave using the built-in password manager
### Actual result
Often times this action requires more than a single click to execute
### Expected result
Button should only need to be clicked once to execute
### Reproduces how often
Easily reproduced
### Brave version (brave://version info)
v1.75.181
(note that this issue has been present in previous releases)
### Channel information
- [x] release (stable)
- [x] beta
- [x] nightly
### Reproducibility
- [x] with Brave Shields disabled
- [x] with Brave Rewards disabled
- [ ] in the latest version of Chrome
### Miscellaneous information
Users reporting the same behavior:
https://community.brave.com/t/double-clicking-of-the-saving-passwords-and-similar-pop-ups/599190/2
https://community.brave.com/t/hard-to-dismiss-save-password-and-other-notifications/570893/2
[https://community.brave.com/t/why-does-it-take-one-click-to-save-a-password-to-brave-t[…]popup-but-anything-between-2-and-5-clicks-to-decline/591980](https://community.brave.com/t/why-does-it-take-one-click-to-save-a-password-to-brave-through-the-popup-but-anything-between-2-and-5-clicks-to-decline/591980)
https://community.brave.com/t/remember-password-dialogue-window-requires-2-clicks/555178
https://community.brave.com/t/double-click-required-in-remember-password-dialog/544346/3
Awesome, glad it will get some attention at some point…
