maqss
February 17, 2025, 1:15pm
1
After a pop-up like “save your password” or “update the info” shows up, I have to double click each of the options, to make it disappear and it’s annoying.
I’ve also started to notice this. It takes two clicks to register whatever button I’ve selected, when clearly it should only take one.
I see this sometimes too, although it’s inconsistent for me. I’ve filed the following issue for our developers to review and included other reports of users saying they see the same behavior:
opened 10:51PM - 03 Mar 25 UTC
bug
feature/settings
OS/Desktop
### Description
Often times when the browser prompts you with a modal to perfor… m an action, you have to click the button twice in order of the action to go through.
For example, the `Save password`/ `Update password` prompt that appears often requires you to click `Save` or `Update` twice in order to dismiss the prompt.
Prompts like this should should require only one click of the button to dismiss.
### Steps to reproduce
1. Login to a website in Brave
2. When prompted, elect to save the password in Brave using the built-in password manager
### Actual result
Often times this action requires more than a single click to execute
### Expected result
Button should only need to be clicked once to execute
### Reproduces how often
Easily reproduced
### Brave version (brave://version info)
v1.75.181
(note that this issue has been present in previous releases)
### Channel information
- [x] release (stable)
- [x] beta
- [x] nightly
### Reproducibility
- [x] with Brave Shields disabled
- [x] with Brave Rewards disabled
- [ ] in the latest version of Chrome
### Miscellaneous information
Users reporting the same behavior:
https://community.brave.com/t/double-clicking-of-the-saving-passwords-and-similar-pop-ups/599190/2
https://community.brave.com/t/hard-to-dismiss-save-password-and-other-notifications/570893/2
[https://community.brave.com/t/why-does-it-take-one-click-to-save-a-password-to-brave-t[…]popup-but-anything-between-2-and-5-clicks-to-decline/591980](https://community.brave.com/t/why-does-it-take-one-click-to-save-a-password-to-brave-through-the-popup-but-anything-between-2-and-5-clicks-to-decline/591980)
https://community.brave.com/t/remember-password-dialogue-window-requires-2-clicks/555178
https://community.brave.com/t/double-click-required-in-remember-password-dialog/544346/3
