Hi, how do I go about making Yandex the Default search engine?
Don’t. All they will do is start spamming you.
If you want to add Yandex as your default search engine, follow these steps:
- Open the browser settings by typing brave://settings or use the Hamburger Menu on the top right.
- Click on “Search Engines” in the settings page
- Click “Manage search engines”
- Click the “Add” button
- Fill in the following:
- Click add
- Click the 3 dots next to the search engine you just added
- Click “Make default”
Much appreciated. Hopefully the spamming issue won’t be a problem as so far, the results it gives back are far superior to any of the other search engines.
Text doesn’t transfer.
Have to copy and paste.
Text transfers with other search engines.
Have only three extensions.
None are context menu extensions or the like.
Yandex I found spams a few of my emails.
How do I avoid the constant CAPTCHAs from searching Yandex from the address line?
I followed the directions above to make it my default search engine.
