Logitech MX Master 2S side scroller not working when logitech options is installed.
Use logitech mx master s2 with logitech options installed.
Go to a webpage that has horizontal scrolling.
horizontal scrolling will work for a split second then stop.
The horizontal scroll will start to move for a split second then stop.
Version 1.13.61 Chromium: 84.0.4147.105 (Official Build) beta (64-bit)
This doesn’t happen when I uninstall the logitech options. After I uninstall that program the scroll wheel works fine. Must be some incompatibility with the two programs or something.
Hi @LRMan97, thanks for reaching out!
That’s good to hear it works with logitech options uninstalled. But if you want to try to get it to work with logitech options installed, you can try disabling Device Recognition in Sheilds or disabling Hardware Acceleration (brave://settings/system), or both.
