I need help with uphold and bitflyer
I am about to authenticate my wallet but uphold does not appear, instead it appears bitflyer from Japan I have to create an account in bitflyer or how can I change to the one of uphold
bitflyer was added to replace uphold for Japanese users
the problem is that i’m not from japan and i don’t know how to change it to uphold
@Ares02 any screenshots?
@Ares02 then, when you click on the verify button it immediately sends you to the bitflyer page without allow you to choose?
on which region are you located in?
@Mattches
if when I try to verify it jumps to the bitflyer page, I am from Central America
Hey Ares02,
Are you currently using a VPN, and what are your current OS language settings?
I have Spanish predefined and no, I don’t use vpn
I have the smae Problem!
I redownlaoded Brave because I had some Issues with Brave Rewards not showing me Ads on my PC and now I cannot reconnect my Uphold Account to my fresh initialized Brave Browser.
My OS language is German and I even tried to download and install Brave with an American VPN, but it didn’t seem to work…
Hello, this could be helpful if you would like to verify Uphold wallet, but showing only bitFlyer option. (Sorry for the complicated operation.)
  1. Quit Brave.
  2. Open the file below on text editor.
[Windows]
c:\Users{username}\AppData\Local\BraveSoftware\Brave-Browser\User Data\default\Preferences
[Mac OS]
/Users/{username}/Library/Application Support/BraveSoftware/Brave-Browser/default/Preferences
  1. Find characters “countryid_at_install” in your text editor.
  2. Edit the number like below.(21843 is the code for US.)
“countryid_at_install”: 21843
  1. Save the file.
  2. Launch Brave.
hi @atsushisa
could this cause the wallet to be flagged?
also @Ares02 is not from the US, not sure if this could cause him more trouble
