How to fix these icon issue
How to fix this icon issues . icons are not loading in any wesites
Could you check whether opening those websites in a private window with all extensions disabled resolves the issue?
yes its works . So its due to any extension ?
That is the usual reason. Check whether those websites work normally in a regular window after you have disabled all extensions. If the websites work normally, I suggest enabling extensions one by one until you find which one is the problematic one.
yea got it its due to “malayalam font pack”
