Hover and click on the buttons are not working as expected in Brave Version 1.36.112 Chromium: 99.0.4844.51 on my MacBook Pro. When I attempt to click any button, it does not register the click in the correct place. Clicking outside the button area works fine.
Furthermore, I am unable to click on any video slider unless the video is in full-screen mode.
To reproduce the issue:
Step 1: Open any website.
Step 2: Attempt to tap the center of any buttons, especially in the footer area of the website.
Step 3: The buttons will not click properly, and it becomes challenging to click, tap, or trigger hover effects.
I have tested the same websites on other browsers, and the issue does not occur elsewhere. This problem has persisted in Brave for the past year. I have also verified that it is not related to my mouse or mouse pad, as they are both in good condition and working correctly.
If a solution is not found, I may need to switch to another browser, even though I am a Brave fan. The previous post on this issue did not provide a helpful resolution (Hover and click on the buttons not working), prompting me to create this new post seeking assistance.
My Information:
Computer model:
- MacBook PRO
Are you using a mouse?
- Yes
Do you have another mouse that you can attach?
- NO
What is the condition of your mouse pad?
- Very New
What USB devices do you have attached?
- NA
What Bluetooth devices do you have attached?
- NA
