Hello guys, I can’t index perplexity as my default search engine on my android device, I tried others search engine and it will index but not perplexity.
Im using the latest version of Brave, I tried Beta and Nighty. but the result stay the same.
Hello,
It sounds like you’re having trouble setting Perplexity as your default search engine on Brave for Android. Here’s a quick solution:
- Open Brave: Go to the settings menu (three dots in the top right corner).
- Search Engines: Select “Search Engines” from the list.
- Add Custom Search Engine: Click on “Add” and enter the following details:
- Search Engine: Perplexity
- Shortcut: Perplexity
- URL with %s in place of query:
https://www.perplexity.ai/search/?q=%s
- Set as Default: After adding, select Perplexity as your default search engine.
Thanks
