I have created a brave wallet I used a password of more than 10 characters, I wrote it down on paper and then entered it twice as requested in creating the wallet, I then carried on and bought a few pounds worth of ether which after a short time was confirmed to have been transferred to my wallet. I then tried to go back to my wallet using the same paper as I used previously to be told my password was incorrect, trying several times with same result. I am reluctant to try the recovery process in case there is a problem with that. What can I do?
Hello! What version of Brave are you using currently?
Thank you!
The latest downloaded yesterday I can’t find the version no in the browser
The file was brave BROWSERSETUPBRV913. exe
It can be found here: brave://settings/help
Thanks!
I’ve only got help tipped
Found it
1.60.118
Says up to date
Sorry I replied on what i thought was the forum
this is what I got
Brave is up to date
Version 1.60.118 Chromium: 119.0.6045.163 (Official Build) (64-bit)
