Hello,
My rewards have been stuck on the same figure for weeks, even though I get 5x ads per hour, usually checking them out.
I have checked other threads and updated, restarted, done all possible troubleshooting. Do date there seems no actual solution to this problem and I would like someone to explain and check this, as it appears many people are having this issue and it remains unresolved.
Cheers
page in the main menu):
