Hi,
I have a problem on android 10, brave 1.5.131 with WebRTC. I tried several conference services that work well on brave desktop and other chromium based mobile browser (bromite, opera).
You can check via:
Hi,
You can check via:
Have you tried disabling fingerprinting in shields? By default all 3rd party fingerprinting is blocked which may be causing the issue
I found that WebRTC works well both on beta 1.8.7 and nightly 1.9.15. So how long does it take to get at least beta into stable?
