Please read through our Help Center articles before opening a topic.
So I cant see my BAT amount
I am on Windows 10 and I am using the latest version/build of Brave
Have you connected your Rewards to Uphold or Gemini? Because if not, you can’t earn BAT. https://brave.com/rewards-changes/
i have and suddenly nothing works - the rewards switch is off and can’t be turned on and even the reset on the rewards settings screen doesn’t work.
