I just learned of the Brave browser and it may be exactly what I was looking for. I just need to know the answers to the following questions to figure out when to use it.
- Is Brave color managed?
- Does it color manage a second display as well as the first one?
- Does it reference the monitor profile with either sRGB or Adobe RGB?
- What does it do to display images without an embedded profile?
- Will it show Adobe RGB correctly on a wide-gamut monitor?
I’m not looking for a right or wrong answer. I just want to understand the capabilities to decide how I might use it. I look forward to your response and appreciate your time.
N/A
page in the main menu):
Brave 1.18.78 Chromium 87.0.4280.141 (Official Build) (64-bit)
Windows 10 Ver. 2004
N/A
