Wallet Swap balances not showing in assets
Same problem - However - While FLUXB balance not showing in brave wallet, JUP dex can see FLUXB in Brave Wallet when connected.
Thank you Benriver!!! I followed your recommendation using phantom and it worked.
I had to learn a little about it - but for anyone else going down this road, “importing your secret recovery phase” essentially grants Simultaneous Access to phantom and brave: You can view, send, receive, and interact with your assets through either wallet.
To remove from Brave (and thus giving phantom sole access - which is more secure) you can remove wallet data from Brave: The process for removing wallet data can vary based on updates and versions, but generally, you would go into the Brave Wallet settings and look for an option to remove or delete the wallet.
https://support.brave.com/hc/en-us/articles/16122730654477-Resetting-Brave-Wallet#:~:text=Alternatively%2C%20you%20can%20enter%20brave,and%20click%20OK%20to%20reset.
