Probably seems absurd but thatβs correct I have been using the platform for awhile I switched it to me default search. But in all this time I have never figured out how to earn a token and if I did how do I link it to my wallet?
Hello @Brad72
what is your platform you using ?
could you send screen shot of what you see no that page brave://rewards/
and have a nice day
Click on the BAT triangle to the right of the search bar.
Then click the button to enable ads. (where 1 is)
You can select the number of ads (where 2 is)
The more ads you view, the higher your BAT earnings.
Best of luck!
