kombins
September 27, 2022, 8:35pm
1
Unfortunately, your Brave Rewards cannot be verified because your region is not supported for Brave Rewards verification at this time.
this is the error I get. what does it mean? what should I do ?
rodrige
September 27, 2022, 8:58pm
2
Turkey is not supported. You cannot connect to Uphold or Gemini.
Your only option at the moment is to accumulate rewards in your browser until your country is supported.
Hello Brave Community,
In consultation with the team at Uphold, verifying Brave Rewards with an Uphold account will now only be available in the following countries of registration, effective immediately (starting July 12, 2022):
Australia
Austria
Belgium
Canada
Denmark
Finland
Hong Kong
Ireland
Italy
Netherlands
New Zealand
Norway
Portugal
Singapore
Spain
Sweden
United Kingdom
United States
For countries no longer on this list, Uphold and Brave will continually work together to evaluate whe…
Brave is trying to bring as much countries back as possible. But this is a hard work that will take some time. I mean months.
You can follow the development of this activity in the following post
For new information, check bottom comment. Otherwise can review some of the below to see overall status since July 26, 2022.
Brave’s List of Supported Countries
OLD UPDATES BELOW: Can’t add more since April 4, 2023.
Update: April 4, 2023
Only because it’s been a little while since I gave an update, thought I’d just do a small post. At this point they still have nothing solid to say about adding countries again, the new partner(s) they are hoping to add, or even of an ETA for the sunsetting of v…
system
Closed
October 27, 2022, 8:59pm
3
