Default is ‘Standard’, can also be ‘Strict’
I’ve been running OK with the default, but I’d like to know more.
What exactly does it do under the covers for ‘Standard’ and also for ‘Strict’?
What is the benefit of ‘Strict’ or what circumstances make it more desirable?
Strict = Only Connect with HTTPS: This means that it won’t ever allow websites to load in HTTP.
Standard = Upgrade connection to HTTPS: This will attempt to upgradethe connection to HTTPS if possible, but otherwise will give you the ability to proceed in HTTP if it can’t load HTTPS without breaking the site.
Disabled = Don’t upgrade HTTPS connections would disable the protection completely. Sites can load in HTTP without attempting to upgrade to HTTPS.
@Saoiray whoops you’re absolutely right — definitely read “Fingerprinting” for some reason and didn’t check twice. Thank you for the correction and great answer as well.
