Due to problems with the functioning of my computers, I had to format and reinstall windows.
When I try to verify my Uphold wallet it tells me that I have reached the maximum number of browsers possible.
I am not interested in losing the proceeds at the moment, but if I need to know how I can do to cancel all the previous browsers to register the ones I currently use.
Thanks so much for any help.
Thanks JohonDproof for the reply. Could you tell me where to look for this form in order to initiate the request for unlinking? Thank you very much for your time and collaboration.
If you follow the link in JohnDproof first reply you will find what I believe you need. By submitting the form linked at the bottom of that post you should be able to solve the problem.
Note that as you have had a device stolen (I think I got that right) you would need to get the information of the ones you want kept active and then Brave can work out by process of elimination the one that was stolen without you having the device’s details.
