Description of the issue
Navigate to http://cafesjarm.ski. When clicking the navigation links such as “MENY” and “OM KAFÈEN”, nothing happens. It works fine in Firefox, but not on Chromium (Version 71.0.3578.98 (Official Build) Built on Ubuntu , running on Ubuntu 18.10 (64-bit))
Exact URL of the website in question
Did the issue present with default Shields settings? [Default states are: Block: Ads/Trackers, 3rd Party Cookies, 3rd Party Fingerprinting Allow: Encrypt Connections enabled (HTTPS), Scripts] (yes/no)
Yes
Does the site function as expected when Shields are turned off? (yes/no)
No
Is there a specific Shields configuration that causes the site to break? If so, tell us that configuration. (yes/no)
No
Does the site function as expected when using Chrome? (yes/no)
I’ve tested Chromium, and it it doens’t work there either. Haven’t tested Chrome - let me know if this is a requirement, or if Chromium suffice.
What Brave version/Build are you using when you encounter the issue?(About Brave info)
- Official: Version 71.0.3578.98 (Official Build) Built on Ubuntu , running on Ubuntu 18.10 (64-bit)
- Beta: Version 0.59.21 Chromium: 72.0.3626.28 (Official Build) beta (64-bit)
