I need help with the Leo IA, it's not working
Leo IA is not working, I’m getting the problem showed below
1- Try to use the search bar
2- Type on Leo option
An answer back
Always
Windows 11, Brave Version 1.68.137 Chromium: 127.0.6533.100 (Official Build) (64-bit)
I just downloaded the app and I’m looking forward to use it as my main browser, thanks
Do you have any extensions installed at this time? Are you using a VPN connection when you see this? Alternatively, are you using Brave on a home network or a network that is managed by someone or an organization?
Thanks for your prompt response! No extensions, this is a clean installation, no VPN, tried different DNS’s but didn’t work, I am at my home desktop pc
