Briefly describe your issue:
I have not received advertising for more than a month and I do not generate bat What Operating System and Brave version are you using (Menu --> About Brave)?
1.37.111 Is your browser wallet currently verified? (yes/no)
yes What date did you verify your wallet?
i dont remmeber Have you been able to successfully receive payments in the past?
yes Are you using a VPN? (yes/no)
no Are you in a supported region (see here for list of supported regions)?
yes Does your device pass the SafteyNet check (Android only)?
i use pc Have you manually turned off Auto-contribute on all of your devices linked to Uphold??
have you tried deleting cookies/cache, updating brave, relaunching the browser and connecting with uphold/gemini again? there’s a bit of a problem with false flags right now and ^ that’s the only way i know of getting the notification to appear to let you know.
