Hello, I am a registred creator, I’ve been verified since january 2021 and somehow my account shows as if I was unverified. Could anyone please help me with this issue? How can I get it fixed? Thanks.
Hi @pbo welcome to Community
Could you kindly submit a ticket to our Creator Support form and from there we can investigate further.
Thanks!
Could you check if your region is supported at
If you’re not from a region listed above, your creators account will show as unverified. Also when you login to your creators account, you’ll see a notice saying so below the connection buttons.
Hi, thanks for the answer. My region is France so it seems to me that it is supported.
Thank you for your answer, Ill submit a ticket then.
