I clicked an icon on the browser and a “Bookmarks” side panel has shown up and I can not find and switch to remove it.
I’ve attached a screenshot
Latest version 1.65.114 (Apr 17, 2024)
Go to Settings > Appearance > Toolbar > Scroll down > Show sidebar button > Disable.
@rlmoon Yes you do. It’s right below Show Brave Wallet and above Show Brave VPN button. BTW, it’s called Sidebar, not Bookmark side panel.
Thanks for the help!!!
@rlmoon also want to give a heads up. Even when it’s disabled, you can still toggle the sidebar on and off. On Windows, it’s Ctrl
+B
as the default command if I remember correctly.
You can go to brave://settings/system/shortcuts
to view what shortcuts you have set. I’m mentioning this as some have unintentionally activated and then had no idea how to deactivate.
Also I’d like to point out that the sidebar has other functionalities beyond just History. For example, you can use Leo from there as well.
