Geolocation Position Error, Brave does not provide position or location when requested
Website using geolocation to get local weather does not work on brave desktop, possibly android browser as well.
  1. Go to https://redskyready.com/wx/
  2. Allow geolocation if it triggers
  3. If the geolocation works additional data will flow in including hourly weather, weekly forecast etc. The website works fine in Edge and Chrome.
  4. Gelocation does not trigger or does not get the data.
  5. Inspect element Error in fetchandstorelocation
wx/:324 Error in fetchAndStoreLocation:
  1. GeolocationPositionError
  2. code: 2
  3. message: “”
  4. [[Prototype]]: GeolocationPositionError
1. PERMISSION_DENIED: 1
2. POSITION_UNAVAILABLE: 2
3. TIMEOUT: 3
4. code: (...)
5. message: (...)
7. constructor: ƒ GeolocationPositionError()
8. Symbol(Symbol.toStringTag): "GeolocationPositionError"
9. get code: ƒ code()
10. get message: ƒ message()
11. [[Prototype]]: Object
fetchAndStoreLocation @ wx/:324
Every time Desktop
Often on Android.
Windows 10
Version 1.74.48
Android 14
There is likely a better way to write my code to fix this but it works on all the other browsers so if you could fix it that would be awesome!
