FIX didn't work, BAT still not porting to uphold
I ran the latest update 1.22.67 this morning, about five hours ago and BAT is still not going to Uphold.
Screen Shot 2021-03-24 at 12.35.23
Screen Shot 2021-03-24 at 12.37.57
FIX appears to be not working, at least for me.
same issue to me. what else can we do?
I have the same problem
I think you need to wait until the 5th
@structdjm I refer you to this posted earlier : -
steevenBrave Support
1
22h
Dear Brave Rewards Users,
If you’ve experienced an issue with BAT not successfully porting from your browser wallet to your Uphold wallet, please upgrade your browser to v1.22.67. Once upgraded, then disconnect and reconnect your Uphold wallet. BAT that was earned before the March Rewards Settlement should then drain directly from your browser wallet to your Uphold wallet.
Thank you for your patience as we’ve worked to implement this fix.
The Brave Rewards team
That sure sounds like any BAT earned before March should port to Uphold after the fix was applied and the wallet reconnected.
i just got updated and disconnected and reconnected my wallet , then immediately all BAT are ported to uphold …
I tried this on both my laptop and desktop computers. Still no March payout.
If your BAT has not successfully ported to your Uphold wallet and you’ve updated to 1.22.67 please DM me your Wallet ID which can be found here brave://rewards-internals/. Thank you.
