I got problem with importing data from Edge Chromium to Brave. There is only the bookmarks import option only. I can’t import a password, browsing history and other things. There is way to make Brave to import the Edge data?
If you want your passwords in Brave, export them into a file and then import them in Brave.
Thanks for help with passwords. Only now thing are browsing history
Brave does not support full user data importing yet.
Hmm, it doesn’t look like there is another way to import browsing data in Brave. I even checked Edge because I have it installed on my computer but there isn’t a way to do it in there either.
