Does screen recording capture sound?
When using the built-in screen recording in an android phone (Android 14), and recording a video that is played via Brave browser, the sound is not captured in the recording.
I wasn’t able to find a setting in Brave that blocks microphone when there’s screen recording.
Using the same recording feature with other browsers, I am able to capture sound.
Is this a bug in Brave android browser or a known feature of Brave (I wasn’t able to find anything in the documentation, so I’m not sure about “known feature”).
@Gil80,
On my Android device, I’m able to record sound using the built-in screen recording. Note that when you start recording, if you want to capture sound from the media playing, you need to select the Media option in the built-in recorder. If you want to capture sound from the mic as well, you need to select Media and mic:
If you’re willing to provide a link to the site in which you’re trying to record, I can try testing on my end as the issue may be site specific.
