Browse Tabs faster from left to right without scrolling through every single on
Hey,
i want to scroll through the tabs of Brave very fast with my touchpad (i am using macbook pro). In Firefox, only the tabs are moving from left to right so i can easily and fast access the tab i want. With mouse it works by mousewheel when the courser is on the tabs.
At Brave-Browser, it works similar. But instead of scrolling the tabs miniatures, i have to scroll throug every single tab instead. This takes time…
Can you add an option, so i can scroll the way i want?
I love your browser, your project. But this is a serious issue for my due to slowing down my workflow massively.
Thanks for answers or - even better - a quick tipp how to change this <3
