Hello, I’ve been using Brave browser for more than 3 years and can not change for any other one. It’s been working fine on Windows for a long time, no issues or anything, but when I use it on Linux I always get something not working properly.
Everytime I reboot the system all the configs I applied to the browser are weirdly reseted back to default, when I check the config they are literally set right as I did but I need to toggle them “off/on” to get them back working (like the brave colors, i configure it to be dark, after reboot its all white but the button says ‘dark’ so i need to change it to white then dark again).
@Icaro1447,
Thank you for reaching out.
Is it all the configuration settings you set in Brave, or is it just the issue with the theme? If just the theme, then this is a known issue that the team is addressing presently:
