April Payout PROBLEM
Briefly describe your issue:
Why is our problem being ignored? Your system does not cause any problems while watching ads. However, your payment system is causing problems every month. I want the payment that I am entitled to as soon as possible and I demand that whatever my problem is solved. Otherwise, I will not hesitate to resort to legal processes.
Version 1.38.117 Chromium: 101.0.4951.67 (Official Build) (64-bit)
No
Yes
Are you using a VPN? (yes/no)
No
Turkey
Yes
