Al tabs window interface and swipe down shortcut DONT work correctly
First of all uninstall is not an option.
The format of tab isn’t working correctly.
What i know is that there are 2 types of tabs:
  1. Group tab
  2. Old style (that I use)
The bug or problem consists in a non stylized interface and swipe down to enter the “all tabs view”.
4 day ago everything was working correctly until I enter the browser and search “synaptics thouchpad for Lenovo”.
Not sure that’s so easy to reproduce. Isn’t like a button bug or something.
The interface of view tabs is not functioning as suppose.
Brave 1.13.115 Chromium 96.0.4664.93
Mobile Device details
Model SM-950U1
Do you have any flags enabled in brave://flags at this time?
Jeje …:smirk:
Yes
But its just
By the way
Ther was another man with same problem. Someone on the comments said he wait for 6 day and the problem solved alone.
So…
Taa adaaa!!
Thank??
