It’s older than that.
I was thinking the same, but worried all my BATs may disappear.
Tell clearly whatever you say.
When will the PC update be released?
After payment, the counter reset to 0
ads are shown, but there are no changes.
what is your current version
we are on Version 1.15.72 Chromium: 86.0.4240.75 (Official Build) (64-bit)
I’m on this version too. But it doesn’t work.
hello @tmancey
@Bananas12 still facing issue with the counter
according to the release note
and the github
is that release should fix the counter bug or i am missing something
thanks and have a nice day both of you
I tested this with VPN enabled and also disabled
the result is the same.
I am using Windows 7 32x
on the second computer exactly the same system, but advertising is running and the counter is working.
just to make sure i got you
your issue that the counter does not work with version 1.15.72 using windows 7 32x
of one of your computers
am i right?
yes, that’s right. I tried to reinstall the browser again, but there was no change
Will they really fix the issue ? I see how much high priority issue this is.
How did you come to know about that?
Hi, the fix is being tested and we are currently looking at releasing in the next 1.15 hot-fix. Thanks
brave nightly is on fire …
Version 1.15.72 Chromium: 86.0.4240.75 (Official Build) (32-bit)
at the moment this version is available, when will the new one be? for 9 days I have not received any advertising.
More precisely, I get it, but the counter doesn’t work.
hey @Bananas12 some people have this problem for months and it’s soon going to fixed. i have the same problem for over 3 weeks now, so please stay patient.
Not for months, but only with the previous update.
I understand that you have to wait, but this does not mean that I cannot describe my problem.
(post withdrawn by author, will be automatically deleted in 24 hours unless flagged)
eveyone flag this fake steeven account so the team block his account
