When will Indians be able to use Uphold or Gemini to verify their Brave Rewards?
I am getting error " Region Not Supported ". Region: India.
Short answer: Nobody knows
Longer answer: Brave has said trying to add all “workable countries” by the end of the year. So hopefully in the next month or so if all goes well.
You can always see more on updates at my own topic if you’d like to follow it. I always post newest on top. So just have to look there (and helps if you go through the collapsible Update times just to see what was going on and said in prior weeks). I’d ignore all the posts/comments on it as a lot of people went off-topic, but that’s up to you. That topic is PSA: Unsupported Region
