Unfortunately, your Brave Rewards cannot be verified because your region is not supported for Brave Rewards verification at this time.
please solve this problem i not connect gemini account.
Unfortunately if you are living in a region that is not supported for either Gemini or Uphold, there is not much more you can do. You can either turn off the ads or continue using them and tip to websites or creators you follow.
I have the same problem, for your region is not supported for Brave Rewards verification at this time, and I have had no problems for the last year of usage. It seems to be a problem with Brave!
