Text issues on 21:9 Ultra wide monitor
NOTE: Any “one-liner” or topics requesting support or reporting bugs that do not make an effort to include as much of this information as possible will be closed immediately. Repeatedly posting as such will get you flagged or banned.
Please try to adhere to this template when reporting bugs. If you think you don’t need to fill out every section in the template fill out as much of it as you can and please be as descriptive as possible when posting. Thank you!
Unable to display text on 21:9 Monitors
Run product on a 21:9 monitor at full screen
See attached
Not to look distorted
all the time
Brave Version(See the About Brave page in the main menu):
Brave is up to date
Version 0.60.48 Chromium: 72.0.3626.121 (Official Build) (64-bit)
yes
attached screen shots
@sbcrumb can you try disable “Hardware acceleration” under Menu > Settings and see if the issue still persist?
Thanks
:slightly_smiling_face:
That did the trick thanks.
