Hi All,
I am running:
Version 1.22.71 Chromium: 89.0.4389.114 (Official Build) (64-bit)
I am running Windows 7 OS.
I would like to set the Home page and new tab backgrounds to a color of my choosing. Is this possible?
How to accomplish this?
If the above is not possible, can provide a custom image file that is to my choosing?
I have spent much time before posting this with experimentation and search-engine searching.
I find many postings, including videos, that show Settings windows that are not what my Brave instance has.
Example is that videos show in the Settings | Appearance, there is a drop down that allows “same as Windows” choice.
My version of Brave does not have that.
Also, as I search the forum I seldom find a posting with an answer (about this topic). Mostly they seem to be “feature requests”
Hope someone can help.
Just go into Settings and look there as I have described.
I hoped for a simple way to set a solid color background.
Thanks !
xbrav
