^ was my original post
I should have rewards from that time but there are none
What Operating System and Brave version are you using ( Menu --> About Brave
Andriod 11 build/RP1A.200720.012 and BRAVE 1.31.91, CHROMIUM 95.0.4638.69
No but I have a wallet
February
Yes
Are you using a VPN? (yes/no)
No
Uk so yes
yes
No contributions
