fred1
January 29, 2022, 9:29am
1
Tested with YouTube videos, whether Auto-Play is enabled or disabled in the settings, the videos will always auto-play when the browser is opened and then the Playlist is opened.
Make sure Auto-Play is turned off in the Playlist settings
Add a YouTube vide to Playlist
Close the browser.
Open the browser.
Go to Playlist and the video will auto-play
For Playlist to not auto-play videos when opening.
Version 1.34.1 (22.1.20.22)
Mobile Device details
Apple iPad mini (5th generation) with iOS 15.3
289wk
February 16, 2022, 3:16am
2
@Go-go_duck ,
Might you help “fred1”, here?
I do not use Playlist nor Auto-Play (meaning, it is always OFF)
Auto-Play - iOS setting on iPhone is:
Settings > Playlist > Auto-Play (there, is an ON / OFF switch)
No Permissions feature / settings
No Extensions feature
There is a “Private Browsing Only” switch:
Settings > Brave Shields & Privacy > OTHER PRIVACY SETTINGS > Private Browsing Only (ON / OFF switch)
@fred1 is using an iPad, and it has different real estate (I imagine); so, his Brave Browser settings are likely to have more features.
My apologies, @Go-go_duck , for bothering you with this iOS issue.
289wk
February 16, 2022, 9:36pm
4
fred1,
At first, the issue seemed to me, at least, to be something that your Brave Browser settings might resolve.
Because I am not a regular video observer, I thought that @Go-go_duck (who seems to know about video), might be able to help you.
But now, unless you can fix the issue by using the Brave Browser for iOS “Clear Data Now” function . . . followed by quitting everything on your iPad and performing a full Restart as recommended by Apple:
“https://support.apple.com/guide/ipad/force-restart-ipad-ipad9955c007/ipados ”
. . . then you have indeed discovered a bug, and possibly @Mattches (Brave Support) can help.
Brave Browser issue at GitHub - Sept. 26, 2021:
opened 06:34PM - 26 Sep 21 UTC
OS/Desktop
(Please note: not tested on Android)
Please note issues that are / seem to / mi… ght be related, at the bottom under 'Misc'.
PLEASE USE THE TEMPLATE BELOW TO PROVIDE INFORMATION ABOUT THE ISSUE.
INSUFFICIENT INFO WILL GET THE ISSUE CLOSED. IT WILL ONLY BE REOPENED AFTER SUFFICIENT INFO IS PROVIDED-->
## Description
With Autoplay set to 'blocked', many (yet not all) sites are
1. not even playing any media (audio/video) based on user input, at least not properly, i.e. when the user clicks 'Play', it is simply ignored (or cancelled).
2. also blocked from 'go to next file', in playlists.
## Steps to Reproduce
**EDIT: added telling example on radiorecord.ru.**
1. Ignoring user input:
A. Go to an affected site (YT for example is NOT affected by this), for example radio.net, or vimeo.com. Twitch is another funky example, as is **radiorecord.ru**.
B. Click 'Play'. In the case of **radiorecord.ru**, click another genre while another one is still playing.
C. ISSUE: the content does not play (not at all i.e. is fully unresponsive or loads indefinitely, or might not play until user clicks pause and then play once again; either way, content is somehow 'overblocked' or at least not 'cleverly blocked'). On Twitch, the sound gets disabled and re-engaging it stops video playback. On **radiorecord.ru**, the second genre refuses to play (unless the first one is PAUSED!!); the intitial genre does not trigger the Autoplay 'Blocked' setting, at all, but the switch to another genre does trigger it, and incorrectly ignores user input ('Play').
2. Playlists
A. Go to (an affected?) site with playlists, e.g. a Youtube or bandcamp.com.
B. Open a Playlist (site with multiple 'pre-loaded' pieces of content ordered for continuous playback).
C. Click Play.
D. ISSUE: insofar part 1 of this issue is not triggered, the file plays, but the next one does not. Having to click Play for every part of a playlist defeats its purpose!
## Actual result:
All scenarios: (immediate) playback is blocked (see 'ISSUE' under repro steps for details).
## Expected result:
1. Playback should work
2. 'Automatic' playback in playlist should potentially be allowed (probably more a feature request than a bug - maybe split?)
## Reproduces how often:
100% - depending on specific site content playback technologies, and how the Brave protocols (do not) handle these, exactly.
## Brave version (brave://version info)
Version 1.29.81 Chromium: 93.0.4577.82 (Official Build) (64-bit)
Win10 Home 19042.1237
## Version/Channel Information:
## Other Additional Information:
No issue with Autoplay off.
Shields do not seem to make a (bug) difference.
**Chome repro TBD**
## Miscellaneous Information:
A few (potentially / somewhat) related issues, maybe this helps. Any linkage we could/should do?
https://github.com/brave/brave-browser/issues/11247
https://github.com/brave/brave-browser/issues/13322
https://github.com/brave/brave-browser/issues/14266
https://github.com/brave/brave-browser/issues/13586
https://github.com/brave/brave-browser/issues/12557
Brave Browser issue at GitHub - Feb. 19, 2021
opened 11:21PM - 19 Feb 21 UTC
priority/P3
feature/autoplay
feature/settings
OS/Desktop
<!-- Have you searched for similar issues? Before submitting this issue, please … check the open issues and add a note before logging a new issue.
## Description
While blocking Autoplay globally and also explicitly for youtube.com, any video content that is opened in a new tab ignores the setting.
1. Browse youtube.com
2. Open any video in a new tab
3. Switch to the newly opened tab.
## Actual result:
Video starts playing, ignoring the setting.
## Expected result:
The setting should be respected and the video must not autoplay.
Every time.
Brave | 1.20.103 Chromium: 88.0.4324.152Â (Official Build)Â (64-bit)
Revision | 6579930fc53b4dc589c042bec9d0a3778326974d-refs/branch-heads/4324@{#2106}
OS | Windows 10 OS Version 2009 (Build 19042.804)
I have not tested with beta or nightly versions.
Using a random extension for the same functionality works as intended.
Looks like I can reproduce this issue as well. I’ve reached out to our iOS team about the issue to see if it’s known. If not I will open an issue on our Github for tracking.
I’ve opened the following issue:
opened 07:56PM - 17 Feb 22 UTC
ipad
iPhone
Epic: Playlist
<!-- Have you searched for similar issues on the repository?
Before submitting … this issue, please visit our wiki for common ones: https://github.com/brave/browser-ios/wiki
For more, check out our community site: https://community.brave.com/ -->
### Description:
When you add a video(s) to your Brave Playlist, if the autoplay option in `Settings --> Playlist --> Autoplay` is set to "disabled", videos will autoplay anyway. My assumption here is that having the option toggled off, that no saved videos should play until the user elects to do so.
### Steps to Reproduce
1. Make sure Auto-Play is turned off in the Playlist settings
2. Add a YouTube vide to Playlist
3. Go to Playlist
**Actual result:**
Videos will autoplay
**Expected result:**
Video should not autoplay
**Reproduces how often:** [Easily reproduced, Intermittent Issue]
Always
**Brave Version:**
v1.34.1
**Device details:**
iPhone/iPad
**Website problems only:**
- did you check with Brave Shields down? N/A
- did you check in Safari/Firefox (WkWebView-based browsers)? N/A
### Additional Information
User reported this behavior here:
https://community.brave.com/t/playlist-auto-play-setting-is-not-working-it-will-always-auto-play-regardless/332447
system
Closed
March 19, 2022, 7:57pm
7
