Hy everybody. It looks like BB is not forwarding any request to Jdownloader. I installed the plugin but it doesnt helped
Are there other ways get it working?
First, welcome to our community forum!
To your question: I had the same problem and the solution to it was easy too. You need to deactivate Brave Shields
temporarily.
Important: Depending on which site you’re, you need to activate
Brave Shields
again before leaving. In my experience the next site I opened, same site but with other links didn’t load correctly because the ads came across your way. So the first time you need to open it with activatedBrave Shields
. Then after the site is loaded deactivate it and use theclick'n'load
button. After that activate it again.
Short Guide:
Brave Shields
is activated. (Lion is Orange, else gray)Click'n'Load
button.Brave Shields
.Click'n'Load
button and add the links to JD2Brave Shields
again.This topic was automatically closed 60 days after the last reply. New replies are no longer allowed.
