how can i use language translator while surfing different sites in brave browser
Hey bijoy3776,
If you go to a website with a language that isn’t listed under Order languages based on your preference
, Brave should ask if you want to install the Google Translate extension as long as Offer to translate pages that aren't in a language you read
is on.
@bijoy3776 as Adrian already told you, you can use the google translate extension and I recommend you to set it like this
