@GlitchGuy it seems like you may need to learn more on how things work. For example, incognito/private doesn’t block websites from recognizing you. The only thing it does is open a session with no cookies and will erase your local browsing history and cookies from that session when you close it. Basically, it’s like trying to prevent your parents or spouse from knowing you were looking at porn.
Websites still see your IP address, can know which web browser you’re using, and other such information.
The website you’re sharing uses a combination of your IP address and cookies. In fact, they don’t even hide what they are doing if you take the time to look. For example:
So they just see IP address, location, browser type, and OS. Then they use that to assume it’s you. They say it works across things like private because they are using IP from your provider.
If you look, I’ve visited the site a lot, but look here…I just went and they claim it’s my first time…
But as said, I’ve visited many times in the past. You can even see examples at Brave stops worries, not tracking - my experience testing brave privacy promises - #5 by Saoiray
Using things like VPN or proxy will help combat this. In fact, on Desktop you’ll see using Private with Tor will show you as a different device.
Please, please, please take time to go research how things work and don’t let yourself fall for silly tricks like this.
As for testing, you might want to check out things like the ones below:
Cover Your Tracks
My Fingerprint - web-am-i-unique
Browserleaks - Check your browser for privacy leaks
They have a lot of little things you can test. Keep in mind there are some things they randomize on us, such as screen size and all. But then there’s also a lot of things they will always display, such as which browser we’re using.
