Hello!
I’m creating a website with HTML and CSS in VS Code and I can’t render (run) the CSS in Brave Desktop, that is, the entire website style (code) doesn’t load, just the HTML. This problem is only on Brave Desktop, in other browsers the CSS loads normally. I pressed the F12 key and I see that there are the following errors in the attached image. I also noticed that Brave did not load the images inserted in the HTML code. So it’s clear that the browser has a serious problem. However, when the website is published on the internet, Brave loads normally without errors, the problem is only with the internal rendering (loading).
Thnak’s!
