Brave is not opening and if i try opening as adimistrator it opens for 0.5 seconds then closing
Brave is not opening and if i try opening as adimistrator it opens for 0.5 seconds then closing started a while back and went back to chrome but the fact that is 10 times worse i want to get back on brave but i tried anything i could find on this community and on the intrent i need help
hey kevin . have you had any luck with it yet i have the same problem and it will not download . if you have a solution let me know please . cheers
If it’s crashing the second you open it WITHOUT hitting restore, then I can’t help at the moment.
Don’t click the restore button on sight, as it’ll crash right there. You should be able to still click that button after this.
Try to visit brave://components, and just update down the line. Once that’s done and all say they’re up to date, hit the restore button. Same suggestion for you @ooal1 if you haven’t uninstalled Brave yet. If you did, go to here https://github.com/brave/brave-browser/releases/tag/v1.46.134 and install that one. If you can’t install that, keep going back a version or two until it works.
If this helped fix the issue, please mark this as the solution to soft-close the thread. If your problems persist and is unrelated to youtube/google, please provide more details if you can, like the current tabs you had open if you remember any.
the fact is not crashing it just closes no crash pop up
Mine crashes when I load YouTube,
Loads DuckDuckGo but click on a YouTube bookmark and it is terminated with extreme prejudice
Yeah. Same was happening to me too. No pop-ups because it’s instantly crashing.
Another update was pushed last night (hadn’t checked since then yet) and it’s back to crashing. Workaround fixes are here:
Or do you mean it’s closing/crashing the moment you try to even open it without restoring tabs? Or would you happen to have YT/google set as your home page?
