@mxx Seems to work fine for me. I guess some of the questions I’d ask:
Are you using a VPN or proxy?
Have you checked your internet?
Does the other search areas work well for you?
Is this intermittent or are you receiving this every time you search?
Which web browser are you using?
Are you using extensions? If so, try disabling or uninstalling
Does opening in a private window seem to work?
