Briefly describe your issue:
Brave rewards promised a 8.198 BAT payment but i received 2.36 BAT
Windows 10, Brave version:
Version 1.52.130 Chromium: 114.0.5735.198 (Official Build) (64-bit)
Is your Brave Rewards Profile currently verified? (yes/no)
yes
What date did you connect a your Brave Rewards Profile?
Around April
yes
Are you using a VPN? (yes/no)
no
yes
im using a PC
Have you fully completed Uphold’s CDD requirements?
yes
