Hi all!
I’m not sure if this is possible, but is there a way to customize the right click menu?
Currently my extensions automatically add themselves and make the menu longer and I have to scroll to get to Inspect. Is there a way to remove those extensions from the right click menu without disabling them from the browser completely? I checked in the Manage Extensions > Options for each and didn’t see anything that mentions right clicking.
I just don’t want to scroll / hover over the arrow at the bottom of the list each time, since I often use Inspect at work and keep missing the button
Thank you!
Currently using version: v1.59.122
Desktop Windows 11
